- Apr 24, 2008
- 3,219
- 448
My goal is to make a contact with a sat this year either with this new sat or AO-51.
AMSAT - The Radio Amateur Satellite Corporation
Hi Wallyhts,My goal is to make a contact with a sat this year either with this new sat or AO-51.
13 July 2011
During the International ARISS teleconference Sergey Samburov, RV3DR announced that the ARISSat battery will be charged late July and a test of the system will be conducted on the ISS from 1915 UTC 30 July to about 1200-1400 UTC 31 July. The standard ARISSat-1/KEDR 2m downlink band plan should be transmitted as well as the FM signal also downlinked on 437.55 MHz. More information as it becomes available.
During the test ARISSat-1 will be in LOW power mode, this means that it will transmit about 40 seconds and then shut down for 2 minutes and then transmit for 40 seconds.
Today we are looking at a 3 Aug 2011 date for EVA 29 and the ARISSat-1/KEDR deployment. This is all subject to change.
Gould, WA4SXM
Apparently the antenna was OK after all, and it's been launched!
Limited time offer
