ASC1 not loading satellite list that has the position from the 1.6 loader | SatelliteGuys.US
jmc98
822
43
32.750N 97.488W Fort worth Tx
I have a USB to serial converter made by TRENDnet model tus9 that will update the asc1 but it would not load the user configured satellite list using loader 1.6 on a windows 7 laptop
Any help or guidance would be appreciated
Did you do a Global Reset then power off for 30 seconds then power on after loading your update?
Also... Do you get an error message from the editor?
Bill
Here's my CSV satellite file that I know works as I just reloaded it a couple of days ago doing the 1.6 to 1.8 editor upgrade. You may try this just to see if your satellite file is corrupted on the off chance. It is zipped to ease upload.
Bill
That is caused by your convertor driver incompatibility with the Microsoft library used with version 1.6.
Consider upgrading to Loader version 1.8 and current firmware 20140730v1. Loader version 1.6 Microsoft library did not work well with several models of USB/Serial convertors.
Reactions: jmc98
was planning on it as soon as i had free time thanks on the suggestion
It's 45 years since the first man on the moon......
Primesat clear transparent 85cm dish
