Aspect Ratio issues | SatelliteGuys.US
Aspect Ratio issues
Dish416
49
Detroit
When my 722k is off & I press 'power' or 'select' to watch TV I noticed that the aspect ratio displayed on the banner is incorrect. For example, it will say 'stretch' even though I am actually viewing a show in 'normal' mode. It isn't until I toggle between all the aspect ratios by pressing the '*' key that it corrects itself.
Anyone else experiencing this issue?
Yeah I've seen that before... Not very often though. Just a minor glitch. You must be like me where it annoys you anyway even if the actual aspect ratio is correct :) .
Another bug, if you view the guide, hover over a particular channel, then cancel out. Pressing INFO twice shows you what satellite the channel you last hovered over is, instead of what satellite the current channel you are on is... That was introduced in L667 for me... The workaround is just press GUIDE and it hovers over your current channel, cancel out of the guide, then check.
Setting up recording to DVR 722 from online question
Multiple Local Markets
