AT&T DirecTV Now Android TV Wireless 4K OTT Client Streaming Player C71KW-400 | SatelliteGuys.US
Richard_E
14
14
Topeka,Kansas
I have Dish network service for now, can I add the Dish anywhere app to the C71KW-400 streaming device? If the Anywhere app can be added to the C71KW-400 I can save rental fees for a Joey I am thinking of changing service to Directv Stream when my contract is over, then use it
Dish Anywhere is available via Google Play so you should be able to add it to the C71.
Reactions: charlesrshell
One more Question. If I can install Dish Anywhere on the C71KW-400 will I be able to use the remote to change channels like I do with the Joey now ? Or will I still need to use their built in channel key pad?
I checked the Play store on my Gemini and the Dish Anywhere app is in the Play store so yes you can install it. I am doubtful the channel numbers on the Gemini remote will work for the channel numbers on the app.
Hopper 3 Version 392 is Here
Joey coax requirements
