Atlantic satellites and/or low-band Ku in the north | SatelliteGuys.US
  • Thread starter Thread starter Jim S.
  • Start date Start date
  • Replies Replies 0
  • Views Views 915
Jim S.
When someone asks you if you're a god, you say yes
5,796
1,542
FN11od
Is anyone located at mid-northern latitudes (I'm at 41 degrees) getting anything other than Hispasat, Telstar 11N, and Telstar 12, or anything on any satellite below 11700 MHz? I can get the first two, more or less (trees starting to get in the way of Hispasat, and T11N only has feeds), and I haven't tried for T12 because it's certainly in the trees. According to signal strength maps, Intelsat 14 at 45 degrees should reach here with a receivable signal on a 36" dish, but I haven't managed to pick up anything from it (the full-time channels are all very narrow transponders, which probably isn't helping), and NSS 7 at 22 degrees should also but that only has feeds, and is probably in the trees for me anyway.
HELP ON HOW TO TRACK MBC FREQUENCIES
Horizons 2 with a 85cm dish
