Audio Glitch only on MPEG-4 Locals??? | SatelliteGuys.US
downthedoor
SatelliteGuys Guru
120
I have a HR22-100 and it seems that every time I watch a recorded show from a local channel there is audio glitches. I do not notice this on live TV or on HD programing from National channels, although I do not watch too much live HD programing. I have checked my signal strength and it seems that everything is where it should be (mid to low 90's,a few very high 80's). Is it possible that this is only on recorded local programing?
Any way to resolve this issue?
The transponder readings are on the
101 are at 95 or better (all but 4,12,18,20,28)
99 are at 90 or better (it is cloudy today)
103 are all 90 or better (it is cloudy today)
For the spot beams:
99: 5 transponders have 85 or higher on cloudy day (6,15, 17,18,23)
103: 6 transponders have 85 or higher on cloudy day (17,18,20,21,22,24)
Those signal strengths look great.
What happens when you pause a live show for a few minutes and then start watching behind real time? Do you still have the problem.
Is this on only one of you local channels or all of them?
i also have the same type of problem. and i have noticed it on multiple recievers.
it seems to go back to the last update to the recievers. that is when i really started to notice it.
it is like the box gets busy doing other stuff and for a brief moment there is a glitch
in the playback.
Dish Alignment
Apps are working!
