Audio Irregularities with B&K Receiver | SatelliteGuys.US
daveoo
20
With VOOM rcrv hooked optically into my B&K 307 I get unpredictable audio. This is not dropouts. I may have audio just fine then switch channels on VOOM and lose all audio. A few more flips of the channels brings back the audio. Having to flip, up or down, thru 2-10 channels before audio returns makes matching audio with the channel I want a guessing game.
Two VOOM rcvrs have been tried with the same problem.
B&K does stand out on having a few audio bugs. And that darn flag. Might try a second optical cable and try PCM.
Hints?
Thanks.
Daveoo
I suspect your A/V receiver is configured to switch inputs automatically. Whenever it loses DD synchronization it falls back to analog input. Check the settings of your A/V receiver and see if you can disable this auto-selection and force one single input type.
Thanks for the advise. Got off my but. Couldn't find exactly what you suggested, but I re-did the settings for processing and got reliable sound for now. The unit is getting rusty and forgets some settings when powered off.
daveoo
This is awesome.
VOOM Instalation Twice NO-SHOWS
