Audio not synced with video? | SatelliteGuys.US
RocketFoot
168
Southwestern PA
Has anyone been experiencing out of sync audio? It has happened twice now and both times, I was able to shut the HR44 off and turn it back on to cure the issue. Is this normal or is something going on?
It happens from time to time. Often a channel change will fix it. As you noted turning the unit off and on can help, too.
Denon AVR/ HR24
DTV HD on r-22 receiver and dish setup.. Help!!!
