audio problem | SatelliteGuys.US
audio problem
crankbait
37
I am having trouble with one audio channel Star5 and Avr. The settings are 11836 v 20765. I have tried other settings but still get the same results, it sounds like two different programs playing at the same time, all the other channels work great.I was wondering if anyone was having the same problem or could tell me what I am doing wrong. Thanks for any reply.
some of the audio channels on G25 like to have 2 different audio tracks...one on the left side and one on the right...maybe the TV audio on right and a radio channel on left
I would check the audio/language button and select either right or left and see if that fixes it. I know that has fixed some channel issues I've run into
I just scanned it in on my Fortec Ultra - sounds garbled L/R didn't make a difference.
Bob
I turned the tv on this morning , Star5 avr working ok. I will try your suggestion if it does it again. thanks
Newbiew wViewStat VS2 set up
satellite tp lists
