Audio Problems need a little help. | SatelliteGuys.US
Krushice
9
In Reno, NV.. Channel 11 the HD audio is great. However, on Channel 11 SD the audio is like someone with marbles in their mouths. Check the signal level and both the HD and SD are at 99. Any ideas how to fix this?
Are you sure it's not a problem at the station? I'm assuming Ch 11's a local channel -- maybe check for a local thread to see if others are having the same problem and might have some info. I'd suggest trying here
http://www.satelliteguys.us/showthread.php?t=11577
or here
www.avsforum.com
or check the channel's website for a way to contact them, and let them know about it.
Check the website and nothing found. Check with the website still nothing. Called the station and they state they havent any reports. Anybody ideas what would cause this? Funny thing this started after the change to new PQ.
Guide questions
Billing ?
