I think Fox does this intentionally. fox is the only channel that has this problem and it usually occurs on a Monday.
Fox sucks
thanks for listening
Fox sucks
Fox sucks
what type of tv,reciever,connection from box to tv???I think Fox does this intentionally. fox is the only channel that has this problem and it usually occurs on a Monday.
Fox sucks
It must be your local Fox. I don't have these problems on our FoxI think Fox does this intentionally. fox is the only channel that has this problem and it usually occurs on a Monday.
Fox sucks
try to force a software download. restart and on the blue hello screen with your remote push 0 2 4 6 8I recently switched from cable to Direct TV. I had Direct TV install hr22-100 in the living room and 2 basic receivers in bed rooms. Everthing worked great untill I tried to turn on the hd receiver. I get all kinds of strange colors on screen I can not access menu or anything else. The only thing I can do is to turn power on hd receiver off and on about 10 times and then I get a distorted picture that will evently clear up and work fine the rest of the day. Every morning I have to do the same routine. I have Direct coming out, but of course they think I have a tv imput problem or bad hdmi cable. I still have cable hooked to dvd player and can switch from hdmi to tv input and have a good picture. I believe I have a bad receiver but can not convince the phone tech. All she can do is read her script! Has anyone else had this problem? Any advice while I wait 4 days for tech to come.
Thanks Ronnie
Fox sucks
Here is the link. Motorboating - Wikipedia, the free encyclopedia
Limited time offer
