Audio Problems | SatelliteGuys.US
Audio Problems
AIA_SMALZ_11
41
Hello All,
I have had my H-10 reciever since Nov. with no problems. Recently i am having problems with the audio when i switch between SD and HD content. Before i could switch and not have the audio fluctuate at all. Seems since the recent update that is no longer the case. Any ideas on how to regulate the audio? I use my reciever at all times for the audio.
I posted a similar question last week, but I didn't get any replies. On my H10, the SD audio is fine. When I am flip to an HD channel, I get a 10-15 second delay in audio. I am not saying it doesn't sync up, it just takes 10-15 seconds for the audio to "load".
Is that the same problem you are having?
I don't have any audio delays but i do get in significant drop in audio volume when switching from SD to HD channels. Never had that prob before.
I have the same audio problem but not on all HD stations. I notice on YES - HD when D* is showing an EI game, the center speaker audio (announcers) has a very low volume compared with the other speakers. It isn't a problem I have noticed with the other HD channels or other Dolby broadcasts.
Active Weather
Weird Channel Setup Change on old RCA Receiver
