Audio Signal | SatelliteGuys.US
Audio Signal
mrite
70
Ottawa Valley Canada
I have a question about the audio on some channels,
The channels are listed as having ac3 whatever that is and I saw some older posts where some of you recommended something to decode ? the audio. So just what is needed to get the audio signal ? My area of interest is with the PBS Stations. Thanks for any help.
if your audio receiver does dolby digital thats the same thing
otherwise there were some headphones out there that do AC-3
dolby & pbs
This recent thread should answer all questions concerning Dolby on PBS and how to decode it.
http://www.satelliteguys.us/free-air-fta-discussion/105965-receiver-s-have-built-ac3-decoder.html
The question comes up from time to time, and it's always a pain to look for the previous thread.
Also, it's not easy for a new member to know how to search for it.
If that solution doesn't suit you, I think there's one FTA PBS channel without Dolby....
I have three or four over-the-air PBS stations here, so I really don't keep up with the problem.
Thanks Guys so after checking out the past posts, I came across a cheap home theater system at Walmart for 60 dollars and it has dolby digital, so am I right to assume that this would solve the problem?
the headphones is a bit cheaper usually less than 20 and you don't have to use the headphones. my is setup to run to a set of powered computer speakers from the Sonic Voom decoder.
also verify if your FTA receiver will output spdif some older receivers don't...
good luck
How to make your own replacement U-bolts for a STAB motor
Advice on RG6 cable for better installation
