Audiovox Hardwire FM Modulator | SatelliteGuys.US
Neutron
Founding Supporter
18,716
1,124
Texas
I have noticed considerable static from my JVC's wireless FM Modulator. It happens on all 4 station selects due to strong FM radio stations broadcasting. I've been considering the hardwire FM Modulator from Audiovox. It will plug into the FM Out port of the cradle. It's either than or spend $70 for a CD-Changer to Aux Input adapter.
Circuit City and Best Buy show this adapter but don't have them in stock. You can order them directly through Audiovox.
http://www.siriusbackstage.com/forum/viewtopic.php?t=11540
Here's the info.
Don't get them off E-bay for $45. That is just a ripoff.
Here's the info.
i got a cd changer to AUX adapter for $35 for my pioneer head unit....
I have noticed that the cd changer to aux input cables are more expensive for factory radios than for aftermarkets. :( Mine is about $60-70.
