Audyssey Pro Calibration? | SatelliteGuys.US
gadgtfreek
22,105
865
Lower Alabama
I notice someone that tours my area does these. Best I can tell is it's compatible with any installer ready AVR (I have a Denon 3313ci) and it allows the calibrator to take 32 measurements regardless of the on board Audyssey version, and they have a Audyssey pro mic.
Anyone have any input? Seriously thinking about doing it.
http://www.audyssey.com/installers
MultEQ XT Setup Comparisons
Features
Do-it-yourself
Trained Professional
Professional Benefits
Maximum number of listening positions measured 6 or 8 32 Collects a more detailed sonic picture of your room, yielding more accurate results
Measurement microphone Audyssey Consumer Mic Audyssey Professional Mic Professional mic is calibrated to the highest industry standards for most accurate measurement possible
Subwoofer/satellite speaker crossover technology Audyssey basic level Audyssey advanced level A more accurate sound blending between the sub and the other speakers
Target Sound Curve
options 1 3 + "midrange compensation" Sound curve can be better matched to your room size and speaker type
Audyssey MultEQ XT
Certificate Not included Included Printed-out certificate displays the sound improvements made to your system
My opinion? Spend your money elsewhere. You have enough experience where you can get things pretty much where they need to be. We only did them on high end setupd and processors that do not come with room correction.
S~
OK. To me the description sounded like they have the ability in my situation to run 32 points, opposed to the 8, effectively making it XT32, along with some other perks. It isnt cheap for the service though.
Pro service can do a lot more than the standard Audyssey set up in the receiver. Question is, is it really worth the cost. Probably not.
S~
XT32 has much more than more microphone positions, it has far better EQ power than the other versions. Pro will not turn XT into XT32. But Pro does give you a custom curve editor and the ability to turn off mid range compensation. Most people seem to recommend upgrading to a receiver with XT32 over adding Pro to XT.
Seriously. Save your money, take a year off of upgraditis, and get yoursef certified. Then go out and do it on the side for some extra cash. ISF certification is only three days for both Levels. ;)
S~
