Auto Change Aspect Ratio on StarChoice | SatelliteGuys.US
JohnnyJupiter
16
Pleasant Hill, California
I used to have my HD channels default to the "normal" (ie - wide aspect) ratio and the non-hd channels would default to the partial zoom (wide aspect) setting, but now they default to 4:3 ratio.
Is there any way to change the settings to get this functionality back? I have it set up that way on my DiSH Network with no problems, but I must admit that I don't know I set that up, either. It just works..
Any help would be appreciated.
Thanks.
JJ
If you have a DVR 530, open the front flap on the right side of the front of the box, its on the bottom right corner on the front of the box, you will see an a/v cable connection and a small red button beside them, press the red button over and over until you get your desired ratio.
Which satellite?
Line Input on *Choice DSR-530
