OTHER - Avenger LNB | SatelliteGuys.US
OTHER Avenger LNB
satkat1
14
Calif.
I have a KSC322-2 lnbf,,my question is at the very front of lnb how far
In is the Hor./Vert. Probs?...it may be 2." I dont realy know,thanks any one on this
The distance from the opening of the feedhorn to the probe position will vary on the LNBF design. Why would you need to know this measurement? The distance from the probes to the feedhorn opening wouldn't be used for any install calculation.
Reactions: KE4EST
