Has anyone tried 'Avenger' lnbf? I am curious if they're any better than JSC321. The price is the same.
I've got three of them to go on my 1.2 meter dish that I will be installing in the next week as the price and shipping seemed to good to pass on and since DMS International has their name on it I feel like it should work OK.
While it may have slight improvements in some circumstances, I prefer the standard JSC-322 over the Avenger version, if not simply for the much better weatherproofing design on the sliding hood that covers the F-connector. The Avenger is not as ruggedly built, in my humble opinion, will not do as well long term against the elements of rain and sun. I have no complaints with the standard JSC-322's performance, so why argue with success?
I tested it yesterday. It's just as good as JSC321s with strong transponders, but it does better than JSSC321S with weak ones. On my VS Ultra box, there was about 5 point increase in signal quality on weak channels, and no noticeable difference on strong channels. Picture quality was the same.
I like it.
Please clarify your comment. Are you saying that it is technically impossible to achieve 0.1dB NR, or that it would make no apparent noticeable improvement even if you could since other factors are more or equally as important? Is it possible that the 0.1dB is accurate but only for a given frequency or narrow range of frequencies as HF antennas can have a low SWR but not have it low across an entire band? I want to find the best LNB with capability for absolute best performance at receiving weak signals. I'm not so concerned about other practicalities like weatherproofing, physical strength, etc. I had thought the Avenger and Spitfire were among those good in this way, but I am not hooked at the navel yet to any LNB: just want to find the best. I don't want another universal; I'm just looking for the best standard linear one can buy.No experience with this model, but it appears to just be another LNBF with doctored specifications. No such thing as a 0.1dB NR. Any LNBF with this claim catches my attention as suspect since the performance specification is already a lie....
Thanks for mentioning that. How exactly does it limit access to the connectors, though? Couldn't you just slide the grey part up again and have complete access? I'm gonna check out that xtreme ii, never heard of it!
cyberham said:Please clarify your comment. Are you saying that it is technically impossible to achieve 0.1dB NR, or that it would make no apparent noticeable improvement even if you could since other factors are more or equally as important? Is it possible that the 0.1dB is accurate but only for a given frequency or narrow range of frequencies as HF antennas can have a low SWR but not have it low across an entire band? I want to find the best LNB with capability for absolute best performance at receiving weak signals. I'm not so concerned about other practicalities like weatherproofing, physical strength, etc.
This is all good to know. But this situation creates a dilemma for consumers. It is usually not a wise policy, in general, simply to buy a more expensive product. More expensive often doesn't necessarily result in better products. If we can't trust technical specifications, and we know we can't trust what salesmen say, then where do we turn? I turn to listening to what actual users of a product give in feedback after personally using a product. And so I am reading what actual users are reporting on this and other forums. Although I rely even more heavily on reading carefully done comparisons of similar products in actual field testing by an organization I trust. It would be good if companies such as yours could do trials in real world conditions comparing different models of satellite related equipment and publishing these results.I can assure you that the 0.1dB NR is not obtained on any frequency with this or any other "off-the-shelf" LNBF. This is only marketing BS! On a line selected and optimized LNBF it is probable to find a percentage that maintains a reduced noise figure and gain characteristics, but it will unlikely to be below a .3 or .4. Uniform gain, phase isolation, stability at operational temperature along with other electrical and design considerations are more of a factor in operational advantages than the NR.
You will not find uniform performance between LNBFs that are simply mass produced and unsorted. The main difference between a higher priced LNB and a lower cost unit is component choice along with the sorting and optimization by the manufacturer.
Limited time offer
