OTHER - AVL Dish Skew question. | SatelliteGuys.US
OTHER AVL Dish Skew question.
Codematic
27
6
Boston, ma
Greetings,
I posted here a year ago about my AVL dish. I have the electronics replaced and can move it remotely with a joystick.
I am trying to understand the skew, I know there is horizontal and vertical polarities. And a skew off of that. The dish has a mechanical skew capability of +-95 deg.
So the picture below I think is a horizontal polarity, with +25~ skew ? Since 0 is the LNB straight up.
But what does a vertical skew look like ? I can move the skew all the way to one side, or the other then when there, tilt it +- back to skew ?
Thanks,
Thinking about this more, it seems that skew on my dish is done like this ?
Thoughts ?
Thanks !
Greetings,
Thanks,
Add + or - 90 degrees to the current ~ +25 degree skew. And yes with the wider opening of the waveguide being horizontal at 0 degrees. It is set to receive horizontal polarization.
In "my" world with voltage switched lnbf. The 0 reference could either be facing straight up or straight down. So if receiving a strong horizontally polarized transponder. Turning the lnbf 180 degrees would receive the same.
Ok great, thats what i was hoping for.
Thanks for the response.
-Lenny
Sorry for the delay, had to put the project on hold for a bit.
Do you store the Horizontal and Vertical Skew servo defaults with each satellite position? If not, save your X and Y axis joystick setting along with the skew Horizontal and Vertical offsets to be called out by Arduino or ???
