AZBox FW updates | SatelliteGuys.US
AZBox FW updates
Magic Static
7,498
4,853
Montana
I pulled out the AZbox yesterday and set it up to see what ity can do. I like this box!! I was going through and checking the settings and working the different features and thought I would check for a FW update. I did the Internet update but it didn't find any newer FirmWare. It didn't even have the FW that came on it. Definately none of the versions being discussed lately. I went to the AZBox site and couldn't find them there. I see we have one of the newer versions on this site and uploaded that one through the USB port. But where do you guys find the newer FW if it doen't show up through the unit itself?
press the home button and go to settings and press ok now right arrow and go down to firmware upgrade and right arrow untill you get it to internet now press the green
button to edit the url now edit the url to this url - http;fw.azupd.com and press ok now press ok and you will have a list of fw that you can load the newest one is at the
top it is fw 5306.
Is this normal for a AZbox??
changing from 9.5020 to 9.5305
