Aztrino 1.82 OSD settings | SatelliteGuys.US
rcard007
2
southeastern NA
Anyone know that file you can edit to save your OSD settings (SX, SY, EX, and EY) so when it re boots you don't have to re set them every time. That would be a big help and a time saver.:)
Tsakman,
Thanks for the info but I did that and it always comes back the same when I reboot. Do I need to edit the file in a different way? I use filezilla. It seams that it is stored in a different spot and keeps resetting it when I reboot. I like the Aztrino 1.82 firmware and many thanks for the cool blind scan that really works.
/etc/tuxbox/config/neutrino.conf
Main settings file for AZtrino including GUI, A/V, Network and miscellaneous settings.
CONFIRMED: Do a Factory Reset on New FW.
The "Dish Moving" popup on the screen
