Bad Bunch of DPP Twins? | SatelliteGuys.US
OkieTech
55
Rio Rancho, NM
I've been installing for over a year and just recently I've run into a lot of dpp twins that show's an odd matrix on both Sat. inputs...119(w/ Green "OK" below and "N.C." just below that)and doesn't show any 110...only occurs on 625 recievers. If I swap out with a 322 it shows the normal matrix. Any other techs come across some of these?
I saw that yesterday, gave me fits. 625 said
port 1 119 OK NC
port 2 119 OK 110 OK DPP switch
I tried unplugging sat lines, running check switch to clear matrix and replugging,
then tried rebooting receiver and check switch.
I unplugged the receiver for 30 seconds, plugged it back in and tried again, no luck.
Then I put in a 322, it worked just fine.
So I put the 625 back in, and VOILA! it was just fine as well.
All while the worried customer sat and watched and kept asking, "Having problems?" I hate that.
I lost the Voom channels
AT&T Home Zone
