Bad Gateway | SatelliteGuys.US
Bad Gateway
Not open for further replies.
Tampa8
Supporting Founder - I'll stand up and say so
18,296
8,133
Tampa/Eastern Ct
I get Bad Gateway when I try to get to this site on the computer and if signed on. Both browsers. Clearing cookies etc only works till I sign in again. I am posting from the app.
Ok, so something is wrong with the site at the least for me and apparently HIFI. I now have a workaround. Go to the Dark theme, then sign in. For some reason signing in when in the classic theme gets me the Gateway message.
I've had the "BAD Gateway' since Friday late afternoon. This is the first time I've been able to get 'on'.
Yep, I still have it. Ok as long as I stay logged in but sometimes when I come back I'm no longer signed in and I have to do the workaround or else I get the bad gateway message.
I haven't seen this in any testing or have found any evidence of it in the logs. However just applied a patch to the system which fixed a number of things, so hopefully it fixes this one as well. :D
I still have it also. Just tried with chrome, no go. FF - same. Then I changed the theme selection, signed in and here I am. Going to try the same with chrome.
Dark theme seems to have the problem. (that's been my choice / with no stickey nav bar)
Just tried on another machine w/ different ISP and had to go thru the procedure* to get on.
Clear history , cache,& cookies, nav to satguys, switch themes. Not the default and not a dark one) then log in.
Been switching themes, and is now Dark. still on. will close browser and attempt to return.
Well there, got right back in. Now going to the other Dark theme and repeat, out & back
selected Dark w/ no stickey nav bar - and an immediate Bad Gateway. Had to do the procedure again to return.
