Bad LNB or DISH pointing? | SatelliteGuys.US
chastulsa
317
SAT A is strong SAT B is intermittent on trans ponder 22, but 23 is strong. SAT C is gone? BAD LNB or should I try to repostition?
Not really enough info here. It may just be an alignment issue. Could be a LOS issue. Could be a bad LNB. Start by making sure the dish is aligned properly. Is this a self install?
audio sync problem with "24" on fox hd
DirectTV HDTV and EDTV receiver
