Hello,
I am looking for a little help.
Here's what I have. Dish 500 which gets satellites 119 and 110 and a dish for local programming.
I have a new receiver that runs two televisions and an old ( maybe 8 or 10 years old) receiver that I keep in the basement. The new receiver is hooked up to both dishes and works fine. The old receiver is just hooked up to one dish, the one that gets satellites 110 and 119.
Now for the problem. The older receiver only picks up channels from satellite 119. If I put it on a channel that normally comes over 110, I get an error message #004 "A problem has been detected with your multi-dish switch". This problem started about two weeks after I had to put in the new card. Mind you it is only hooked up to one dish. The reception off 119 has always been sketchy at best. When it rains, without 110, I have no TV. (It's been raining here for over a week!) And the kids are out of school on Friday!!!!
I called DISH Tech support and they told me it was a problem with the switch between the receiver and the dish. They would gladly come out and have a look for a minimum charge of $49.00 plus any parts and additional labor.
I looked at the switches online and figured it would be easy to change. The problem is I checked from the box to the dish and found no switch. On the dish are the two eyes and (I guess you would call it a splitter) for the two satellites. One side says 119 and the other 110.
The cable comes out of there and runs along the ground. When they installed it they just stuck it in the basement window. I drilled a hole and ran it through the outside wall about 4 years ago.
So, is the switch inside the case that says 110 and 119? Why would one receiver work and not the other?
I really don't want to pay to have someone look at it just so I can keep paying to watch tv. If it comes to that I'll go back to digital cable.
Thanks so much for your time
