Bad Receiver??? | SatelliteGuys.US
Bad Receiver???
tonysoprano
13
I have Directv 5LNB dish and 2 new HD receivers (not DVR), I get my locals in HD. Anyway, my question is this. One of my receivers seems to be changing the picture color from Blue to Green. Do I need a new receiver or is there something I can do to prevent this?
Are you sure it's not an issue with the component video cables (if you are using any)? Make sure they are plugged in all the way/matching the right colors or try another set or hdmi cable.
I agree with the above posters. Check or replace the cables.
Problem with HR10-250
HOW TO GET 95 WEST Of Direct TV?
