No I do not lose a signal so it could be new software o and thanks for a fast reply.Possibly new software is causing the low signal level readings.
You may see a signal level message on your check switch screen regarding this issue. Read those notes
Are you losing signal or seeing acquiring sat signal message.
If so, try running a check switch. This can be found in your owners manual.
yes and yes..And you got a crappy deal...Is there an easy way to get a good tech to check If dish was Installed correctly?
First tech did not do a good job even left open cables on the ground
It's what I have 322 system.AFAIK the new signal meter software is only on the 322 as of now.
Correct..and onlt after it is in use..The software is not factory..so the SS is "normal" upon install....AFAIK the new signal meter software is only on the 322 as of now.
Dishcomm stated that his strength from a dpp plus twin was rolling at 110 strength..... is that from a duel or a single tuner? Single tuners are always much higher then duels.. you can have
301 - 120 strength out of 125
625 - 110 strength our of 125 and be hooked to same LNBF
but now as everyone else stated.. the 322's being low.. anything at this point around 60 - 70 is good strength.
I just installed a 301 and it was peaked at 120 and the 322 was right at 72 strength. Both connected to same dish and same LNBF. Its just new software.
When I talk about signal strengths I'm going for main transponders on 119 SAT.. usually 119 #11 and #16, 17,
Limited time offer
