Bandstacked Shootout or Why Amps Are Good and Bad | SatelliteGuys.US
pendragon
1,101
66
I've put up three WaveFrontier T90 toroids over the past months to cover the North American FTA Ku birds. Considering the number of orbital positions involved, the use of bandstacked LNBs makes a lot of sense in terms of limiting the cost and complexity of cabling and switching. However the choices for bandstacked Ku LNBs is very limited. Until recently the only commonly available option was to salvage feeds and LNBs from Dish Network 105W and 121W SuperDishes. Then Sadoun released the KLBS1 LNBF which I evaluated a couple of months ago, here. I've been trying to decide on the final configuration for my toroid LNBs, and decided to have a shootout.
The competitors were:
1. Sadoun KLBS1 LNBF. I strip the plastic case to provide better mounting on the toroid rails. The KLBS1 has LOFs of 10750 (H) and 10100 (V), meaning H is sent from 950-1450 MHz and V is sent from 1600-2100 MHz. This unit has a lot of gain and a high output level.
2. Dish FSS LNB + 105W feed. Of the two stock SuperDish FSS feeds, the 105W version is the easier to work with. The horn mouth is small and the waveguide is set up to handle circular polarization if rotated by 45 degrees. Like all Dish FSS LNBs, the LOFs are 10750 (V) and 13850 (H), meaning V is sent from 950-1450 MHz and H is sent from 2150-1650 MHz (inverted). These LNBs have much less gain than the Sadoun units.
3. Dish FSS LNB + 121W feed. The second SuperDish feed is compromised because it had to work next to a 119W feed. The horn mouth is narrow and tall to accommodate this. The waveguide is also extended to allow physical space for both the 119 and 121 LNBs. Both the 119 and 121 feeds are cast as a single unit. Common practice is to separate these with a hacksaw.
4. Dish FSS LNB + DP feed. Given the striking similarity of the Sadoun and DishPro feeds, I couldn't help but chop a DishPro LNBF down and bolt the remaining feed to a SuperDish LNB. I wanted to see if I could improve on the original SuperDish feed performance, which isn't that inspiring.
All of these are shown in the attached pictures. The mod to couple the DP feed to a SuperDish LNB is pretty much self-explanatory. One of my toroids is centered on 97W, which has a lot of high CNR transponders to use over the H & V ranges. I chose six and for each competitor made quick CNR measurements of each. At the same time I wanted to test the benefit of using amps at the dish. There isn't a lot of cable to my test setup, but there are switches, taps and other paraphernalia in-line that make using the SuperDish LNBs a bit on the ragged edge with its low output level. So each competitor was measured with and without an amp in series. The entire signal path was the same for each test and I made the changeovers as quickly as possible. The same SuperDish LNB was used for the three feeds to prevent having that become a separate variable.
The measured CNRs are listed tabularly and are plotted in the attachments. I also included a table showing the relative performance of each combination with respect to the DP feed + FSS LNB, which overall came out on top. Finally there are a table and plot of the 'benefit' of using an amplifier for each competitor. Not surprisingly the Sadoun unit does much better without an amp. It has a very hot output compared to the Dish FSS LNB. The Dish FSS LNB showed some significant improvements with the amp.
Comparing the best amp configuration for each competitor, my DP + SuperDish LNB concoction was the overall winner. The Sadoun unit was very competitive, beating the winner by small margins on three transponders. However it was behind by larger margins on the other transponders. The stock 105W and 121W feeds finished farther back. Averaging the relative performance compared to the winner for the six transponders I calculated:
1. DP feed + FSS LNB: 0.0 dB (reference)
2. Sadoun KLBS1 LNBF: -0.5 dB
3. 105W feed + FSS LNB: -1.8 dB
4. 121W feed + FSS LNB: -3.3 dB
The above data show the importance of a good feed, as the first and last place finishers used the exact same LNB in the tests. The Sadoun is a readily available unit at a reasonable price and it performs very well. However the modified DishPro feed, which looks almost identical to the Sadoun feed, when coupled to a SuperDish LNB does outperform it. There may be some unit-to-unit variations, but quick pretesting I did with other Sadoun and Dish LNBs showed nearly identical results.
There are other factors other than CNR. I did not evaluate phase noise, nor did I look at LO frequency accuracy/stability. It should be pointed out the results are for a T90 dish; the feed matching to other Ku dishes may be different. The SuperDish parts are largely only available through eBay. The modification is very easy, but it does entail sacrificing a DishPro LNBF and you are left with the SuperDish feeds. For my purposes I plan to combine the top two units. Where I need to achieve 2 degree spacing on the same toroid, alternating the two gives just enough space to squeeze them in. I will have to slice off some small pieces of the two feedhorn mouths to get them to fit, but this is very straightforward.
  • CNR vs. TP vs. Config.pdf
  • Amp Effect vs TP vs Config.pdf
Pendragon;
Good stuff there....I've been toying with changing over my array to bandstacked both for cabling ease as well multiple receiver benefits. Your graphs clearly show the benefits of a decent feed.
I also liked your earlier WB autopsy, with the regulator mod, was that 6 ports in/4 out?
I've been a big fan of DP34's for quite a while as they provide some gain and are pretty much bulletproof, but limit you to either all bandstacked lnb's or only 1 receiver per switch. With an external power supply, a DP34 per each bandstacked lnb trio, and a goto(xx) switch per receiver, I could easily get a dozen birds with stuff I have laying around .
Thanks for the inspiration! (I glad you have a SA and shared your results)
Cadsulfide:
Thanks for your comments. The idea of using a bunch of DP34s is a great idea because that switch is certainly designed to pass the full bandstacked spectrum. In terms of other switches, I wrote a thread on modifying a WNC 4x8 and another for a Zinwell 6x8. While I used the WNCs for a few months after starting my toroid project, it rolls off quite drastically at the top end. The Zinwell 6x8s work much better. However two of the inputs are virtually useless as they appear to work only with DirecTV LNBs and receivers. Keep us posted on your expansion project when it comes to pass!
Pendragon, great research. I'm a big fan of the Eagle Aspen P870s (they're usually free ;) ), and its nice to see that it is, indeed, a quality LNB. Seems that much depends on the feedhorn... I had been wondering why the Dish FSS stacked LNBs (rebranded P870s) were considered inferior, performance-wise. I have mine attached to a 1 meter Channel Master with the original Channel Master feed, and have outstanding results on 125w.
Excellent thread, well set out and easy to comprehend results. Full kudos to you Pendragon especially using a torroid as the test bench.
CNR is by many an overlooked issue these days. I have never been a fan of Amps but now with less access to the mil spec range of LNBs clearly they have their place.
Nice review and comparison. Any suggestions we can do to improve our LNBF are welcome.
Since the DP34 switch is discontinued, we have the JVI branded DN34 switch available in stock:
Dish Network Approved multi switches DP34, DP21, DP44
  • This is similar and compatible with DP34 switch from Dish Network.
  • Three satellite inputs for use with up to three satellite orbital locations with bandstacked LNBFs
  • One Input for Over The Air Terrestrial Antenna or CATV.
  • Four outputs for connection to up to four independent receivers.
  • Contains a built-in diplexer for combining off-air signals with satellite signals onto a single home-run wire to the dwelling. This is a nice feature in this switch that the DishPRO DP34 does not have
  • Switch may be cascaded 3 switches deep
  • Does not require power insertion.
  • Can be used indoors or outdoors.
I don't know whether this is a systemic problem, but I forgot to mention that when I pulled the feed caps off a couple of KLBS1s it was apparent the vertical RF probes weren't perfectly aligned. I trued them with some long nosed pliers and this improved the vertical frequency linearity and CNRs for both LNBFs. The unit I tested in the report was 'fixed' in this manner. If it hadn't been, the results would not have been as good.
In an unrelated note, I also forgot to mention that modifying the DP feed requires that the dielectric plate inside be removed. Otherwise it won't do linear polarization.
Quality threads like this are much appreciated.
Is a DP feed preferred for some reason?
The feed from a legacy LNBF looks similar...
Quality threads like this are much appreciated. Is a DP feed preferred for some reason? The feed from a legacy LNBF looks similar...
Thanks, as long as people are benefitting I'll keep publishing what I learn. As far as legacy LNBFs are concerned, I wouldn't be the slightest bit surprised if they worked the same. I don't have any at the moment, but I was shipped one by accident and never noticed this until it didn't work as expected on the dish.
Could you elaborate in more details on apparent WNC switch deficiency? Point to your Zinwell switch thread? Any other suggested low cost high end switch to accommodate 3 or 4 dual LNBFs (band stacked or not) to 3 or 4 Sat Receivers?
The WNC 4x8 works fine for normal North American Ku and C-band LNBs that output from 950-1450 MHz. This is the spec and they are not misrepresenting their product. I have a number in use for that purpose and have no plans to change them out. In fact they will pass signals much higher in frequency and when I steer my big dishes to birds with extended C-band spectra, everything also works fine.
When I started testing bandstacked LNBs on my toroids, I was initially impressed that the WNCs would pass signals to 2150 MHz. That was certainly better than any other 4x4 or 4x8 switches I had tried. I was aware the Zinwell 6x8 switches were necessarily spec'ed from 250-2150 MHz, but at that time the prices on those switches were many times that of the WNCs, so I built my switch matrix around the latter.
Later when I investigated an unrelated problem, I did testing that demonstrated I was suffering a high frequency roll-off in the WNCs (mostly above 1900 MHz) that under unusual conditions was limiting my reception. I also have tons of data establishing the frequency responses of a lot of different switches and amplifiers that I did as part of this exercise, but I made some minor procedural errors in a few cases. Until I have time to correct those, I am not comfortable with publishing incomplete or possibly marginal results. But the data were clear the WNCs were not the best choice for bandstacked LNBs.
Fortunately the Zinwell 6x8s are now much lower in price and work perfectly for this purpose. As I had published a thread on how to mod the WNC switches for +18V powering of LNBs, I published a similar thread on how to make the 'unpowered' Zinwell switches provide a similar capability:
http://www.satelliteguys.us/free-ai...ghty-mods-iii-6x8-switch-power-insertion.html
If you're considering bandstacked LNBs, by all means go with the Zinwell 6x8 switch. It's the only 4x4, 4x8 or 6x8 switch I've tested that will easily pass 2150 MHz. If you don't need anything more than 1450 MHz, I'd still recommend the WNC switch. It's much better than unpowered 4x4 switches and the best of the 4x8s I have tested. There may be other alternatives I have not investigated, but you would be on your own.
To Pendragon:
If you were to attach the FSS LNB to the Superdish feedhorn without removing the insert, how good of a job would it do for 118.7?
If you want to do 118.7 with a FSS LNB, I think there are at least three options:
1. Chop the feed off a DP or legacy LNBF and bolt the feed to a FSS LNB. I would actually pull the dielectric plate out and reinsert it to align it at the requisite 45 degree angle with respect to the LNB's vertical and horizontal probes. Otherwise you have to bolt the feed on at a 45 degree angle. This should be the best performing approach.
2. If you have a 105W feed, it can be rotated 45 degrees CW when mounted to a FSS LNB to get circular polarization (it has some flats on the waveguide). This would be the second best solution.
3. If you have a SuperDish 119/121 feed, separate the two with a hacksaw and use the 119 side as is with a FSS LNB. This should work, but the gain will be the lowest of the three options.
AMC 21
Has anyone set up an nFusion Phoenix
