Bar with 16 Receivers. Diseqc Question. | SatelliteGuys.US
s10jam
2
Erie, PA
We have both cable and DirecTV in the bar at the moment. We are looking to drop cable in and go strictly with DirecTV. Currently, we only have 8 receivers on a pvms-8ep diseqc switch. What is the best option for us to take so that we can run 16 receivers? Can we get another pvms-8ep or do we need a 2x16 diseqc switch?
Is this SD only?
The 2x16 would probably be the easiest. You could do another 2x8 but then you'd need 2 high frequency splitters to put on the outputs of the LNB
LNB output 1----splitter 1 port 1-------------2x8 input 1 switch 1
LNB output 1----splitter 1 port 2-------------2x8 input 1 switch 2
LNB output 2----splitter 2 port 1-------------2x8 input 2 switch 1
LNB output 2----splitter 2 port 2-------------2x8 input 2 switch 2
CenturyLink Switches From Dish To DirecTV
DirecTV pips rival DISH from CenturyLink web
