Update: I got the G4 Smart Card and installed it into the 211k, called Dish and added the news pack including BBC World to my package of AT250, Movies, HBO, and Supers. The Flex packs now can be added to AT 120-200-250 packs.
Too much duplication
For at250
Yes, I have the G4 card, and I have been enjoying having BBC World with AT250 for awhile now.I thought they always could be added to other packs...with the G4 card, of course.
Now, if you remove the pack within 30 days...
it does cover other countries with the MSM left slant...
It is a news channel...kindaMy response will be confined to The Pit. Do you go there?
I read earlier that only AT200 and Flex could get BBC World. Apparently Dish quietly added in 120 and 250. Hopefully Dish will add to AT250 in time. I wonder why BBC World is not in HD though?
I can't imagine a channel on 200 that's not on 250.
As to HD- I'm sure there's a rea$on.
Fightbox is the channel that is now in AT120+, but not in any other package, if I remember correctly.At one time it was true you could not add the pack with BBC to Top 250, could to Top 200. Also there is a channel... maybe Fox Sports 2 can't remember that was in top120+ but was not in Top 200. (It now is) Only Charlie knows why.
According to one CSR I talked to, so many people complained that they could not get BBC World, Dish decided to offer the pack to any AT 120-200-250 customer that wanted it.
It is in the 'compromise' 14:9 format. Use the partial zoom with Dish to get it to fit w/o cropping. Samsung's wide fit also works.Is it still offered in that weird format that results in the top and bottom of the image cut off when you zoom it to the normal widescreen setting for all other letterboxed SD channels?
Limited time offer
