Bell coverage maps (both 91W & 82W) | SatelliteGuys.US
  • Thread starter Thread starter Mr Tony
  • Start date Start date
  • Replies Replies 0
  • Views Views 21K
Mr Tony
3,208
14,434
Mankato, MN
Now with the new satellite up at 91W and its "different" coverage here are maps of both 91W & 82W
91W sat coverage is pretty simple
the red area you should be fine
If your near it a bigger dish MIGHT help
outside of that...sorry but no go
82W is a little different
within the 52 or 54 ring a 20" dish should be ok (but bigger is better)
49 would need probably a 30" or even a 36"
44 would be a 1 meter or 1.2 meter
outside of that is usually a no go
91 map
attachment.php
82 map
attachment.php
There is also a thread that helps with 82W a little more as the footprint isnt 100% correct as some folks can get signal outside of the outer ring with a larger dish
http://www.satelliteguys.us/canadian-satellite-services/166004-nimiq-82w-contour-map-first-take.html
Reactions: T95KPRO and nob0dy
