I have a 18" DirecTv dish with a dual lnb which I split into an 8 way multi-switch. I currently have just 4 receivers hooked up but plan to add some more soon.
I have replaced my LNB before because after about 6-7 years the cap had disintegrated and after each rain I got terrible reception for days. Well after 2 years later I thought the same thing was happening again so I went online (ebay) looking for a new lnb. I was suppose to get an Eagle Aspen DTV32+ LNB however it seems that the seller sent me a DirecTv 18LNBR0-02 LNB instead. Should I be concerned? Is one better than the other?
If I wanted to get the most out of my 18" dish, which LNB would be the best?
FYI, I am not so sure that my currrent problems that prompted me to get a new LNB are necessarily related to the current LNB that I have. I went up on roof today and discovered that bees have made a home inside all of the dish support mount tubing. I gave it a quick sqirt with bee killer but will need to go back up once sun starts to go down (too hot now). Regardless to whether the old LNB is bad or not, I will probably still replace it and still want to know what the best one to get would be.
