Best FTA Receiver ? | SatelliteGuys.US
Best FTA Receiver ?
Mikey11
858
16
canada
i am going to attempt some c-band on a 1.2m offset dish very soon, i am wondering what the best receiver to use for this application would be?
i guess im looking for a receiver that will still display a pic even at low signal quality because im kinda expecting low quality numbers, also something that blind scans very well, and runs a motor well, i will be using a new SG9120,
i was thinking of pansat, coolsat, icon or traxis, what do most of you guys use? any specific models?
thanks
Coolsat 5000 for its blind scan abilities. Now if you are into High Def content, and want to get most of it then get yourself a receiver that can do DVB-S DVB-S2 4:2:0 & 4:2:2 like the AZBOX HD can.
Also if you have a strong PC/LAPTOP then you can also get a PCI/USB card that can do the same.
Are there Satellite Trade Shows any more
I need opinions about Prof Revolution DVB-S2 7500 USB
