GaryPen said:If I'm not mistaken, your Dish receiver probably has a nifty feature we like to call the PROGRAM GUIIDE! I can understand you not finding it, though. The remote button is cleverly hidden next to the word "Guide".
chaddux said:It's much easier to grab a book, open it, find the appropriate time block, find the appropriate channel, follow the column, the find the program, then follow the column back to the time, then pick up the remote, then watch the program.
Having to use the remote to the thumb through the programs is very difficult. If you are trying to see what is coming up on a certain channel, you have to hit RIGHT...RIGHT...RIGHT...RIGHT. And the worst part is that it's free. It makes a lot more sense to pay for a book than to use the free guide.
This has been a sarcastic response to a sarcastic response brought to you by the letter Q and the number 7.
The thing with Titan all the other online you cant add your locals tothe DISH guide atleast I dont see who.BFG said:Use an internet guide, specifically http://titantv.com
You can create a custom guide with just the channels you want in it.
trido said:The thing with Titan all the other online you cant add your locals tothe DISH guide atleast I dont see who.
Trido
Yes, works fine! Just did mine. Did not work the first time, must have been temporarily confused!Bobby said:Sure you can with TitanTV. Just click "Customize" and then "Add" and fill in the call sign for the local channel and the channel you want it to appear on.
Limited time offer
