What is the best iPhone FM Transmitter & Car Kit? I am looking at one that has the least amount of interference
Do you get any drops, interference, or noise? My XM transmitter never gives me problems, but I think it gives out a much stronger signal and the modulator I put in helps a lot as well.Walmart.com: Griffin Universal iPod Accessory Bundle: Audio
I got this at WAL Mart. Works fine. It has auto scan or you can put it in manually. Charges with USB.
I was out looking around at retail store prices of some of these transmitters. I think the better option for me is to get a new car stereo. They have some for around $100 with both an auxiliary port and a USB port. I can use the auxiliary for my XM MyFi and the USB for my iPhone. I would end up getting a better signal with both and have a better radio as well.
All of those I was looking at said iPod/iPhone compatible.:up:up
That's the best choice I believe. I went through a couple FM Transmittors living in L.A. and it's just not worth it. Constantly was changing frequencies, it had AM station quality sound and just wasn't worth the hassle. Ended up getting a new stereo myself. You can go with either an Auxiliary Port and control from your iPhone, or a USB jack if your stereo is iPhone compatible (I would double check on this, a lot are "iPod" compatible, few are "iPhone" compatible) or you can get one with stereo bluetooth and take advantage of the new feature in fw 3.0. Either way is a lot better than an FM Transmitter.
Is stereo bluetooth as good as USB and/or Axillary?
The other issue is the stereo console in my truck. The space is huge and the stereo is small. I would need to look into getting some sort of facing to cover the huge gap that will be left.
I was particularly looking at the KD-HDR50
The only thing I will need is the mounting accessory. The stereo has a USB port already and I have about 5 iPod/iPhone USB cords lying around.Looks like a decent system, although you'll want to get the iPod connection accessory so it will run you a little more scratch.
Limited time offer
