Best place to buy directv RG6 cable in lengths | SatelliteGuys.US
john510
23
United States
where is the Best place to buy directv RG6 cable in lengths say 15 ft 25 ft etc?
compression connectors would be great ..All so can any of these be buried in the ground?
How many 25 foot cables you need ?
You'd almost be able to buy a roll of coax and make your own sizes by the time you buy specific sizes.
The compression fittings and correct tool for them are available at HD and Lowes
HD and Lowes don't usually sell solid copper RG6 which you would need if you have a long cable run from the power inserter to the LNB. But they both sell copper-clad steel which is fine for short runs.
Amazon and Ebay have pretty good prices on RG-6 coax and the fittings. You will also need to buy a cutter, wire stripper and crimper.
Getting an AM21
AM21 vs other antennae
