Best place to buy quad shielded plenum grad RG6 cable | SatelliteGuys.US
Paradox-SJ
1,636
2
San Jose, California
I am in the process of pre-wiring a new room at home and would like to know where is the best place to buy cable quad shielded plenum grad RG6 cable.
Thank you for your suggestions...
Why do you need Plenum Quad Shield? Good old RG-6 is plenty good. Can get it at any home depot.
FWIW, quad shield is a PITA to deal with as far as putting fittings on correctly and in most situations, is totally unnecessary. Unless you have some crazy fire codes in your house, plenum is another unnecessary cost too. Just my 2c.
His location is California where there is crazy codes for everything.
Yeah but unless its out of the ordinary, regular RG6 shoukd be fine. I install in cali.
He probably just wants to over kill like my friend did.
He asked how an installer would hook up his gear, i told him how. So he went and bought quad shield cable and ran it himself.
I second that . Plenum is over kill on your pocket unless your planing on burning down your house but want to watch tv at the same time..
POS CCS plenum the cable co uses is $200+
SC plenum is around $300(fell of a truck)-1200+ dual or quad
SC quad RG6 should be around $75-100 and would work well even if you have crap runs next to power or pushing 200'
You missed my sarcasm
What is the TV output jack for on the OTA module? (MT2)
Do you leave EHD plugged in?
