Best Universal Remote for DSR-410 that doesn't "Break the bank?" | SatelliteGuys.US
radio
"On the Air" in MI
3,738
908
West Central Michigan
Hadn't seen this addressed yet.
I've been using a Philips SRU4208WM/17 (Long name for a simple remote, best to google it) but...the buttons wear out, (have had two of 'em)....and want to find a universal that will for sure learn the functions of an original GI/Motorola remote, plus handle Vizio TV, Toshiba DVD-R, and maybe a couple other things. But, the major thing is, it must learn the DSR-410.
I tend to doubt that any of the "download via USB" fancy ones even know about hte existence of many of the things we satellite experimenters have in our equipment roster...so "learning" is a must. (If you've owned original birdview, you know that's true.)
What are the assembled here using for control, and what are the pluses and shortcomings found relative to the DSR and modern TV functions?
Can't use a 920 or 922 remote....'m still running that receiver as a positioner for FTA in the same room, and (luckily before) the end of our datastream on 4D, the factory reset of my new 410 also reset my 922. Luckily it is NOT a brick.
Hope this is interesting for all!
Any older Starchoice remote will run the 410. The 4DTV's usually can't access the satellite menu though with most *choice ones. I got my hands on a Starchoice URC 547 lately and low and behold the DVR list button handles the satellite menu and the remote is UHF too. That remote is used on the Shaw DVR boxes. Works everything on the 4D :) You can run 2 DSR's in the same room by changing the addresses. I have the 405 on one code and the 922 on another no issues. All *choice remotes seem to handle my tv's too. :)
I think Starchoice remotes should be easy to get and cheap.
Yeah an old Starchoice/Shaw Direct remote works fine
Also the old Voom remotes work too
heh...checked Ebay and Voom remotes are $9 with free shipping
Do the voom remotes work the satellite function? Thats a must on the 4D but not the 410's.
I need to check out the VOOM remotes I have to verify. Currently I'm using a remote that came with a DSR-405 ( I believe this is correct) that is brown in color (P/N: 413318-001-00) model IRC-431.
If I remember right the 410 from Skyvision came with a black remote. It's been two years but I'm pretty sure about that. Brown is usually a *choice at least thats what my 405 has.
I have the original, and you are correct. Black is what my Ebay seller sold me, all properly wrapped, cared for and in great shape! Any suggestions for all in one's? Seems unless its the two pizza providers, most "universals" are not...unless they learn. I love a good "gadgety" remote, but only if it works and is comfortable.
[QUOTE] Generic Remote Control for Motorola 4DTV
.topImage { margin: 0px; padding: 0px; width: 200; height: 10px; } .middleImage { margin: 0px; padding: 0px; width: 200; } .bottomImage { margin: 0px; padding: 0px; width: 200; height: 10px; } div.option { text-align: left; margin-left: 15px; } .buttons { padding-bottom: 5px; }
View Product Images
Price:$44.99
Availability:in stock Prod. Code:UR4-DSR
This is a generic replacement remote control for all MOTOROLA C-Band satellite receiver.
This R/C is IR only and will control the following models plus any 4DTV.
    • Motorola/GI DSR 300 and 400 satellite series
    • TV and TV/VCR
    • Audio
    • VCR
    • DVD
    • PVR
Features and Benefits
    • Robust Code Library (TV, VCR, DVD, Audio,TV/VCR, PVR and Satellite).
    • Macro Power Button - (Turns all devices on and off).
    • Memory Lock - Guarantees 40-year memory protection for the device codes.
    • Factory-Direct Pricing - (not available from some of the other remote and OEM vendors).
    • Custom Logo - Used to enhance consumer brand awareness.
    • Available in Gray or Silver Case Style.
    • Coated Buttons - Used to prevent wearing of text print.
    • Back-Lighted Device Buttons - For easier operation.
    • Easy, Simplified Set-Up Procedure.
    • User Guides - (multi-lingual availability).
    • Inventory Management - For just-in-time delivery. East and West Coast warehouses.
    • Near Zero Failure Rate - 99.98% failure-free production.
    • Unmatched Technical & Marketing Support.
    • Fluorescent (Glow-in-the-dark) Keypad.
Specifications
    • Size: 2.5" (W) X 8.7" (L) X 1.2" (D)
    • Weight: 4.2 oz
    • Case: Custom design model
    • Power Supply: 2 X AAA Alkaline
USER'S MANUAL AND BATTERIES INCLUDED
[/QUOTE]
I don't claim to have the best, I pick up cheap remotes from flea market. Been using a Cinema 7 One for All URC7200 for some time on 4dtv 905 and 920. Not sure which code I'm using now, but have 869 and 1900 scratched on batt cover as 4D codes that work in Cable/Sat mode. I have another model One for All that also works. Been using the first one for years, wife gets the original.
Rumors of Discovery
free 10' mesh, Leesburg, VA
