You guys requested them, so here they are, a better look at the SuperDish feeds and LNBs!
(Click the pictures to see them full size)
Stargazer said:The first one they are coming out with will be the 2 inch pole. The other dish will not be out until next year in which will use the 2 3/8 inch pole. I am sure that there will be adapters. Someone on here mentioned something about making an adapter for the different sized poles vs. the size needed. If you were to get the 2 3/8 inch pole you could get U-bolts and bolt the mast to that pole and then if you were to get the other dish later on then you would have the correct size for that particular dish.
bcw said:I wonder if the 2", or 2 3/8" pole question might be that 2" nominal pipe actually has a 2 3/8" OD. (REF: ANSI B36.10-1979, American National Standard Weights and Dimensions of Welded and Seamless Wrought Steel Pipe).
MikeD-C05 said:My question is this what will I do if I want to have a dishpro quad and run it to all 4 receivers ? Or will a switch be needed in order to avoid the dishpro quad , like the dish pro 34 switch ?
Stargazer said:The 110 and 119 lnbf's have to be adjusted independently? Darn, no wonder why they are going to require professional installation for this dish. I can see the posts now with problems with this dish.
Limited time offer
