Better to connect via phone or ethernet? | SatelliteGuys.US
smjbh5
414
5
SF Bay Area
I have a 622 that I will connect to avoid the $5 monthly fee. Is there any difference between connecting via the phone or ethernet? Any additional features?
I use both...
I do the phone life so I get the caller ID screen pop
I do the ethernet so I can use the dish.sling.com to program my DVR from the web.
No difference in cost avoidance. You may get the 'no phone connected' message if you don't have the phone line - but they tell you that the ethernet method is fine. If you can do both (even with VOIP) they each have their advantages.
Its April 1 st Where's the HD ??
TV2 remote 6.2
