I am going to try out a CM-4228 and if it works whats better to run from the roof to my basement distribution block? 300ohm is the flat wire stuff right? I have RG6 for my 75 ohm. Thanks guys.
bnaivar said:Actually, 300 ohm wire is MEANT to have a higher loss than 75 ohm coax. it's original purpose was to LOSE signal between the antenna and the TV. When TV's were first coming out a lot of people were putting up far larger antennas than they needed and overloading the tuners on their TV's. TV installers resorted to the 300 ohm wire to lose a substantial portion of the signal but still have enough for a clear picture.
I didn't believe this story until I tried it and read the difference on a signal level meter.
jmcgee_jr said:That would make more sense due to fact it has a higher resistance factor.
When cable first came to our town they charged extra for each TV you had hooked up. I tapped off the cable with twin lead wire (because that's what I had available) and ran from the main TV to the kitchen and bedroom. I came home from work one day and my teenaged son met me at the door all bug eyed, apparently 2-3 guys from the cable company came by and had detected signal leakage and unhooked my set-up and told him to tell me NOT to hook it up that way again!I remember when I was like 10 years old and I ran cable to my room because I was sick of rabbit ears. I got one of those 75/300 ohm transformers and ran (2) 22 gauge wires accross the carpert with duck tape.
Worked nice, until my mom got sick of seeing the wire and made my dad drill a hole to run radio shack coax cable. I remember buying the cable which cost me $20, which was alot of money to me back then!
Limited time offer
