D dlh1435 SatelliteGuys Pro Original poster Apr 6, 2004 169 0 Jul 19, 2005 #1 I just moved and couldnot keep my dish.there is a tree in the way.now if I went with directv which I think wouldwork.IT is a little to the left and there are notrees.my zip is 45227.can someome check it out for me.
D dlh1435 SatelliteGuys Pro Original poster Apr 6, 2004 169 0 Jul 19, 2005 #3 there is a tree in my way.if I went with direct you think I could get a signal.my zip is 45227.
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Jul 19, 2005 #4 dlh1435 said: there is a tree in my way.if I went with direct you think I could get a signal.my zip is 45227. Click to expand... How do you expect me to see the tree on the internet and answer your question? You need an installer physically there to answer that question!!!!!
GaryPen Rich or poor, it's good to have money. Supporting Founder Mar 2, 2004 16,677 605 I only lived in California. I'm FROM Brooklyn. Jul 19, 2005 #5 dlh1435 said: there is a tree in my way.if I went with direct you think I could get a signal.my zip is 45227. Click to expand... Let me check my magic 8 ball.
H HD921 SatelliteGuys Family Feb 2, 2004 65 0 Jul 19, 2005 #7 kavula said: ^ "Maybe." Click to expand... If you move the tree Dish will work
SimpleSimon SatelliteGuys Master Supporting Founder Feb 29, 2004 5,692 4 Florissant, CO Jul 20, 2005 #8 Oh come on guys. Per http://emantechnology.com/lookangle.asp Bird=Azimuth 119=230 110=220 101=208 in degrees magnetic. SO, yes, MAYBE basic D* on 101 would work - but the 3-LNB unit won't (obviously).
