Bird dog question | SatelliteGuys.US
Bird dog question
holeshot
ohio
I am thinking about starting to install Direc tv.I was wondering what Bird dog I will need to start as far as what version,what satellites I need to lock on etc.I seen diferrent versions on ebay and I am not sure what I will need.
Birddog USB or USB PLus if youre gonna install SWM equipment.
need
72.5
95
101
110
119
101 SWM
119 SWM
on any installs you lock your primary.. and that is 101 and you need strength on 119 too.
and probably some more i havent listed.
i still currently use my birddog USB even though they gave me a USB PLUS. i find my USB model more accurate than the USB PLUS.
only time i use my PLUS is when the SWM lnb is on the SL dish and i can plug it into a splitter with the Power Inserter is plugged in bc it powers the LNB and to see what kind of signal bc without the power inserter plugged in, you get nothing.
when i install a SWM system, i use a SL3 to dither my dish, then change LNB to 3SWM LNB and then after the install is done, should be on the mark. if not, plug the USB Plus into the splitter and dither.
OR you can get Directv's new AIM meter. its supposely to have 99 and 103 which you would need to pick up if your area no longer rely on 72.5 for locals. 99 and 103 are HD satellites.
Satbuddy has 99 and 103 from what i hear from a DNS tech that plays darts with me here.
Question
D* Tivo On It's Last Leg ??
