Birddog USB Plus | SatelliteGuys.US
Birddog USB Plus
GreatFTA
1,389
15
Mississippi Delta
How well does the Birddog USB Plus (v.4) work with searching for the satellites?
I ordered a used one on EBAY that is working great but had no cords (programming and AC). I paid $135 for it.
It works ok for fta satellites it doesn't search for the satellites you have to program in the ones you want to use the birddog on
Great! Thank you, jmc! I think I'll enjoy using this meter. I downloaded the manual and other info on this. For $135 I hope it work. Seller said it was used 10 times and there were no defects. Just no cords. I got both of them.
