Birdies / harmonics and combining RTL SDR device | SatelliteGuys.US
cypherstream
650
79
PA
This is a 3 part post (rather than 3 separate posts).
Birdies
Do you encounter a lot of signal birdies? For example off the top of my head at exactly 144.0000 MHz, there appears to be a very strong birdie. Huge signal peak but the audio is nothing. It opens squelch to silent audio. There's a few of these around even in the 1000-1300 MHz range.
Harmonics
Also do you ever pick up signals shifted to alternate frequencies because of harmonics? I have one at 859 MHz and it appears I'm also picking it up at 932 MHz.
Combining
A third question... if one of these only has a 2.4 MHz bandwidth, could you combine two to get 4.8 MHz, or combine 3 to get up to 7.2 MHz bandwidth? Just thinking on trying to cover wideband data transmissions to pass through GNU Radio. (Like QPSK and QAM).
