Birdog and downloads | SatelliteGuys.US
dodge
1,197
Plano, Illinois, United States
Anyone here use a birdog???
Just bought one, it is only set up for directv , I want it to do dish as well, have the cable for downloads. Birdog.tv is down anywhere elses to get downloads for the unit???
Dodge, take The Tates advise.. only use Birdog.tv When you get everything programmed I'm sure you'll love the meter. Are you doing any D1000's yet?? If so and you are going to use the BNirdog... use the DP dual on the 119 to aim the dish, I have found that to be the easiest and that is what Birdog recommends. I also the check signal strengt on the 110 and 129 with the dual before putting the LNB's on. Hope everythign is good for ya. - Rob
Birdog and Dish 1000
I bought the Birdog last week to do 2 at 9 Hi Def Installs, loved it worked great fast aiming.
Yes I am doing Dish 1000's did one saturday used the good old digisat and the yell out the window method, but I want to set up the birdog for all dish stuff as well.
I went on birdogs site last night and it was down, but i got it today..
Rob the dp dual worked well and superdish is up and running thanks!!!
I reecomend the birdog to all installers it will save tons of time...:D :D :D
[TWC] South Dayton Ohio subs: How does the HD look? Are analog channels acceptable?
Surewest anybody?
