I have a Birdog Ultra and need to download satellites into the meter. Can't find anything. Anyone have anything for me. Thanks
It appears that the downloads are no longer available. Not sure what should be done to get my meter to be a useful tool. I have look into this to the point of frustration. Don't know what to do about a meter for alignments. Anybody have any ideas?
Yeah. I've checked on that. Noone seems to support the product anymore.
Here is the reader. I have two saved parameters lists but need to determine what they are. I will send them soon as I can.That is the site for the manual instructions, etc. And it is available. The information I am looking for are the actual satellite parameters to load into the
meter. That collection is no longer anywhere I can find. Thanks though.
Both of mine are Plus so I cant copy them and my sat list will not work. I am looking for alternatives.Here is the reader. I have two saved parameters lists but need to determine what they are. I will send them soon as I can.
Yes, that is probably the file I could use but need the same type birdogultra_log.....etc.Both of mine are Plus so I cant copy them and my sat list will not work. I am looking for alternatives.
Anyone need some info use with cation and double check before use
Did you ever get a response to this question? I have need of the exact same thing.Hey all,
Sorry to resurrect an old thread, but has anyone made any kind of progress on this? I managed to get an old version on birdog.tv working on WayBackMachine, but the config SAT files would not download from Wayback. One of these other links in this thread includes a zip file with a handful of SAT files, but none of them are 99W (Galaxy 16), which is what I'm looking for. Does anyone have some old config files?
Thanks!
Limited time offer
