Birdog ULTRA vs Birdog USB Plus 4.0 | SatelliteGuys.US
carver188
12
Colorado
I am considering buying a new satellite meter and was wondering if anyone knows the difference between these two. I will mainly be using the meter on the Dish 1000.2 and the Dish 500.
This is what I found to be different, but don't think I need most of it: All-In-One Zip Code Look Up, Spectrum Display, Expanded Measurement Display, All-In-One Power Solution and a new Constellation Diagram
Thanks for the help and input
for what you want the 4 should be good ... but later if you go to direct the ultra would be handy ...i got a 4 from ebay the other day for 190 ... in great shape ... like new...but i want the ultra
Dish HD OnDemand for 1080p only?
Considering come back to E*
