Some of the guys have built their own.
We've had a number of discussions on how to go about it.
I got a bunch of magnets and an idea to build about 10 kits, but haven't followed through with the project.
Here is a thread where I made a magnet wheel/reed sensor setup for a Birdview H-H mount.
http://www.satelliteguys.us/c-band-satellite-discussion/166422-phlats-birdview-2-a.html
Do an Advanced Search on the FTA forums for threads started by "linuxman" with the word "birdview" in the title. Tons of awesome pics and detailed instructions to be studied there, he ain't the Prez of the BVOC (Birdview Owners Club) for nothing!![]()
Phlat, where did you buy the magnets? I downloaded the templates and think I might be able to dupilcate your plans, proabably want turn out as good as yours , but maybe it will work. I assume you glued them inside the wheel. Anole if you had the kits available, would relieve you of one, hehe. thanks to both of you. The bull
Here is where I got mine, looks like the same seller still has a current auction:
Search for this eBay Item #: 180292540335
I did apply some glue to the holes but they were a press fit, the glue was just a little insurance.
There is nothing too tough about making one of these magnet wheels, I just took ideas from others that had made them before me and adapted their ideas to what materials I could find, and asked a LOT of questions of the guys here.![]()
There are a number of different configurations in the field.can't you glue magnets to the white wheel at the end of the main worm gear axle and put a reed sensor on a bracket that is nearby?
Limited time offer
