OTHER - Biss1 compatible with I-Link 9600 receiver | SatelliteGuys.US
OTHER Biss1 compatible with I-Link 9600 receiver
Richinald
35
7
Aruba
Hi, just wanted to receive if possible some advice if the I-Link 9600 receiver if it is compatible with a HD broadcast but has Biss1 code, but we are able to get the Biss 1 code (legally) but not sure if the I-Link 9600 can accept a Biss 1 code, however the I-Link technical specs shows that there * BISS CAS Embedded
Any advice would be very much appreciated, Thank You
Hi, just wanted to receive if possible some advice if the I-Link 9600 receiver if it is compatible with a HD broadcast but has Biss1 code, but we are able to get the Biss 1 code (legally) but not sure if the I-Link 9600 HD receiver can accept a Biss 1 code, however the I-Link 9600 receiver technical specs shows that there is BISS CAS Embedded
Any advice would be very much appreciated, Thank You.
